| • | To launch the Match Motion dialog box |
| • | To match motion to a tracking path |
| • | To unlink overlay clips from tracking paths |
Using the Match Motion feature, you can automatically match the motion of overlays and titles with a tracking path to create the effect of one element following another. For example, you can identify a moving person in a video by matching a title name to his tracking path.
The path of the motion as manually defined. This is shown only in the Customize Motion dialog box.
Reset — Discards all actions. This is shown only in the Customize Motion dialog box.
Save to — Saves the active paths to the path library. This is shown only in the Customize Motion dialog box.
Cancel — Closes the Customize Motion / Match Motion dialog box and discards any changes made on the video.
OK — Closes the Customize Motion / Match Motion dialog box and saves the path tracked as a video clip attribute.
Match Motion / Customize Motion right-click menu
Launches the Grid Line Options window that modifies the grid line settings.
Displays/hides the other tracks in the Timeline.
| • | Right-click an overlay clip on the Timeline and choose Match Motion. |
| 1 | Insert a video with tracking path in the video track. |
| 2 | Insert a title clip in the overlay track and adjust its properties to match your project. |
| In this example, the name of the boy in the video is added to the title track. |
| 3 | Right-click the title in the title track and select Match Motion. This opens the Match Motion dialog box. |
| 4 | If you have more than one tracker, select the tracker that you want to match. |
| In the sample video, Tracker 01, which represents the tracking path of the boy, is selected. |
| 5 | Adjust the properties of your title depending on the requirements of your project. |
| Each time you set a value, a key frame is added. |
| In this example, Offset values are adjusted to set the ideal distance between the boy and the title. The Size and Opacity values are also adjusted to make sure that the title is visible and yet a bit transparent. |
Note: If you need to turn and move the clip around the video, you can set the values under Offset and Rotation. You also have the option to add a shadow and border, or mirror your image. Clicking the Ease in/Ease out button |
| 6 | Play the video to test your animation. When done, click OK. |
| The result of our sample project is shown below. |
You can tweak the properties of your overlays and titles by using key frames, dragging the tracker and adjusting values in the Match Motion dialog box.
| • | Right-click the overlay clip and select Remove Motion. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
