Before taking the actual screen capture, make sure to configure the settings of the video first.
In File Settings, specify the following details: |
Filename — Enter a filename for your project. |
Save to — Lets you specify the location where you want to save the video file. |
Capture to library — Enable to automatically import your screen capture to the Library and identify the save path in the Library. |
Format — Choose an option from the available formats in the drop-list. |
Frame rate — Lets you specify the number of frames to be used when recording. |
In Audio Settings > Voice, do one of the following: |
Click Enable voice recording to record a voice-over. Click the Sound Check button to test your voice input. |
Click Disable voice recording to disable voice-over recording. |
5
In Control Settings, the following options are available: |
6
In Monitor Settings, choose a display device. |
Full screen — lets you capture the entire screen. When you launch the Screen Capture toolbar, this option is enabled by default. |
Custom — lets you specify the area to capture. The capture area dimensions are displayed accordingly. You can also specify an application window to capture by choosing an option from the list of active programs. |
Click Settings to access more options. |
Click Start / Resume Recording to start the screen capture. |
Note: You can press F10 to stop and F11 to pause or resume the screen capture. |
4
Click Stop Recording to finish your screen capture. |
The screen capture is added to the Library and to the custom folder that you have specified. The video can then be imported into the Corel VideoStudio Pro Timeline and you can trim the clip or add effects and titles.
For more information, see Edit media and Titles and subtitles.
To create a high quality video, use the applicable Windows Media Video (WMV) profile in the Share workspace. You can also enable Same as First Video Clip to use the settings of your screen capture recording when rendering your video.
For more information, see Saving to video files for computer playback.
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
