| • | Motion Tracking interface basics |
| • | To launch the Track Motion dialog box |
| • | To track the motion of video objects |
The Track Motion feature allows you to track the motion of a point or area in a video and automatically generate a tracking path in the process.
Track Motion works in tandem with the Match Motion feature. Match Motion allows you to make your overlays and titles automatically follow the tracking path that you create.
If you prefer to manually animate overlays and titles to match your main background video, you can use the Customize Motion feature.
Track Motion — Tracks the motion of the selected tracker in the video clip automatically.
Reset to default position — Discards all actions.
Track in / Track out — Specifies a working range in the video clip where motion is tracked.
Zoom in / Zoom out — Adjusts your view of the Video Timeline.
Show tracking path — Shows or hides the tracking path in the Preview Window.
Add tracker / Remove tracker — Adds and removes trackers
Rename tracker — Renames the active tracker
Save to path library — Saves the active paths to the path library.
Set tracker as point / Set tracker as area — Toggles between using the tracker to follow the motion of a specific point or area
Apply mosaic — Applies a mosaic effect over the tracked object. This button lets you blur the area of the tracked object.
Add matched object — Adds a matched object and lets you adjust the position from the Position drop-list or the Preview Window.
Cancel — Closes the Track Motion dialog box and discards any changes made on the video.
OK — Closes the Track Motion dialog box and keeps the path tracked as a video attribute.
| • | You can do one of the following: |
| • | Select a video file on the Video Track and click the Track Motion button |
| • | Click Tools > Track Motion and choose a video file. |
| • | Right-click a video clip on the Video Track of the Timeline and choose Track Motion. |
| 1 | Click Tools > Track Motion. |
| 2 | Browse for the video that you want to use and click Open. This opens the Track Motion dialog box. |
| In this example, a video of a boy walking by the lake is selected. |
| 3 | Drag the tracker to the part of the video that you want to track. |
| In the example, the tracker is dragged to the face of the boy. The area is magnified to give you a closer view of your selection. |
Note: If you want to select a larger area, click the Set tracker as area button |
| 4 | Click the Track Motion button |
| The video is played as the tracking path is generated. If Show tracking path is selected, the tracking path is displayed and highlighted once the tracking process is completed. |
| 5 | Click OK. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
