Adding cues and chapters helps you to navigate through a project and allows you to place comments on your Timeline. These cue and chapter marks are used mainly as project guides or disc menu chapters and interactive links in HTML5 projects.
Cue points serve as markers that help in lining up media clips in a project. Chapter points specify disc menu chapters or hyperlinks.
Note: You can also use the Cue Point Manager when adding cue points. Select Add and specify the timecode and name of cue for easy identification. Click OK and then Close. |
You can also add a cue point by dragging the Timeline slider to the desired cue point position in your project and clicking Add/Remove Cue Point.
Select Chapter Point in the Chapter/Cue Menu. |
To remove chapters and cues, drag the markers outside the Timeline ruler and release the mouse button. You can also drag the Timeline ruler to a chapter or cue point and click Add/Remove Chapter Point or Add/Remove Cue Point.
You can also drag the Timeline slider to the desired chapter point position in your project. Click the Add/Remove Chapter Point.
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
