Corel VideoStudio Pro allows you to customize video filters in a variety of ways, such as by adding key frames to your clips. Key frames let you specify a different attribute or behavior for your video filter. This gives you the flexibility to determine how your video filter will look at any point in a clip and to vary the intensity of an effect over time.
Click Customize Filter. The dialog box for the video filter appears. |
In the Key frame controls, drag the Scrubber or use the arrows to go to the frame where you'd like to change the attributes of your video filter. |
4
Click Add key frame to set that frame as a key frame in the clip. You can adjust the video filter settings for that particular frame. |
6
Use the Timeline controls to edit or to go to a key frame in the clip. |
Click Reverse key frames to reverse the sequence of key frames on the Timeline such that the sequence starts with the last key frame and ends with the first key frame. |
7
Click Fade In and Fade Out to establish fade points in your filter. |
10
Click OK when finished. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
