The new workspace is designed to provide you with a better editing experience. You can now customize the size of the program window and change the size and position of the elements on your screen for full control of your editing environment.
Each panel behaves like an independent window that can be modified according to your editing preferences. This is very useful when you are using large displays or dual monitors.
The main panels are:
1. Player panel — Contains the Preview Window and Navigation area.
2. Timeline panel — Contains the Toolbar and Timeline.
3. Library panel — Contains the media library and the Options area.
You can also drag the panel outside the main application window into the second display area for dual-monitor setups.
Click the Restore button and drag the ends of the program window to the desired size. |
Click the Maximize button for full screen editing. |
Click Settings > Layout Settings > Save to and click a Custom option. |
Click Settings > Layout Settings > Switch to and choose Default or one of the custom settings you have saved. |
You can also change the layout settings from the UI Layout tab in Settings > Preferences.
Click Settings > Preferences or press F6 to launch the Preferences dialog box. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
