| • | To save a transition in My Favorites |
| • | To delete a transition from a project |
You can collect your favorite transitions from different categories and save them in the My Favorites folder. This way, you can easily find the transitions that you use most often. You can also delete transitions that you do not use.
| 1 | Select the thumbnail of the transition. |
| 2 | Click the Add to My Favorites button |
| • | Do one of the following: |
| • | Click on the transition to be removed and press [Delete]. |
| • | Right-click on the transition and select Delete. |
| • | Drag to separate two clips with transition effect. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
