| • | To split a clip into two |
| • | To trim a clip with the Trim markers using Single Clip Trimmer |
| • | To trim a clip directly on the Timeline |
| • | To trim a clip using the Duration box |
| 1 | In Storyboard View or Timeline View, select the clip you want to split. |
| 2 | Drag the Scrubber to the point where you want to split the clip. |
Note: Click |
| 3 | Click |
| 1 | Double-click a video clip in the Library or right-click on a video clip and choose Single Clip Trim to launch the Single Clip Trim dialog box. |
| 2 | Click and drag the Trim markers to set the Mark-in/Mark-out points on the clip. |
| 3 | For more precise trimming, click on a Trim marker, hold it, and use the left or right arrow keys on your keyboard to trim one frame at a time. The Mark-in/Mark-out points can also be set by pressing [F3] and [F4], respectively. |
| 4 | To preview the trimmed clip only, press [Shift + Space] or hold [Shift] and click the Play button. |
| Note: You can also use zoom controls to display each frame of your video on the Timeline and trim one frame at a time. The Scroll Bar makes navigating through your project quicker and easier. A wheel mouse can also be used to scroll, and to zoom by pressing [Ctrl]. |
| 1 | Click a clip on the Timeline to select it. |
| 2 | Drag the Trim markers on either side of the clip to change its length. The Preview Window reflects the position of the Trim marker in the clip. |
| 2 | Click the timecode in the Duration box in the Options Panel and enter the desired clip length. |
| Note: Changes made in the video Duration box only affect the Mark-out point. The Mark-in point remains unchanged. |
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
