CorelDRAW.app, CorelDRAW, and Cloud
Available exclusively to CorelDRAW Graphics Suite and CorelDRAW Technical Suite users, CorelDRAW.app is a web-based application for creating vector graphics. Access it from any device to capture your ideas into designs instantly or share your designs with customers.
CorelDRAW.app is integrated with CorelDRAW. You can save files created in CorelDRAW.app or CorelDRAW to the Cloud, an online storage, and then open these files in either one of the applications. For example, you can create a design in CorelDRAW.app, save it to the Cloud, and later edit the design in CorelDRAW, taking advantage of its wide array of editing tools. After you finish editing, you can save and upload the file to the Cloud directly from CorelDRAW. The edited file can be opened in CorelDRAW.app for annotation, but not for editing, and then saved to the Cloud. If you need to edit the file, you can open it in CorelDRAW.
A project dashboard helps you store, view, organize, and share files saved to the Cloud. You can share a file by copying and sending a link to its location. Everybody who receives the link will have the access privileges that you choose. You can also share a file with specific people by specifying their email addresses and access privileges.
CorelDRAW.app and CorelDRAW share some features, but they also differ. For information about saving, editing, and opening files with CorelDRAW.app, view a tutorial from within the app by clicking Help Learning Tutorial.
Important notes!
To open files created in CorelDRAW.app in CorelDRAW and vice versa, you must save them as CorelDRAW (CDR) files.
The first time you access the Cloud from CorelDRAW, you will be prompted to sign in with the password associated with your Corel account. You need to sign in only once a year.
An Internet connection is required to open files from and save files to the Cloud.
If you need to sign in with different credentials, you must first sign out of the Cloud (Help Sign out of Cloud).
To access CorelDRAW.app
Back to Top
1 Go to https://coreldraw.app.
2 In the Sign in to Cloud dialog box, type the email address and password associated with your Corel.com account.
If you are a corporate user of CorelDRAW Graphics Suite, you can also sign in to CorelDRAW.app Enterprise with your corporate Microsoft 365 or Google Workspace account.
To open a CorelDRAW (CDR) file saved to the Cloud
Back to Top
1 In CorelDRAW, click File Open from Cloud.
2 On the project dashboard, double-click the file you want to open.
You can also open a CDR file from the Cloud by clicking the Open from Cloud button on the standard toolbar.
To save a CorelDRAW (CDR) file to the Cloud
Back to Top
1 In CorelDRAW, click File Save to Cloud.
2 On the project dashboard, choose the folder where you want to save the file, and type a file name.
3 Click Save to save the file and upload it to the Cloud.
You can also
Save the file to the Corel DESIGNER (DES) file format, or to an earlier version of CorelDRAW
Choose the file format and version from the File format and version box.
Break the link between a file saved to the Cloud and its locally saved version
In CorelDRAW, click File Save As, and save the file to the local folder you want.
A file saved to the Cloud can be identified by the cloud icon beside its name .
You can also save a CorelDRAW file to the Cloud by clicking the Save to Cloud button on the standard toolbar.
To find, organize, and view files saved to the Cloud
Back to Top
1 Click File Save to Cloud or File Open from Cloud to show the project dashboard.
2 Perform a task from the following table.
To
Do the following
Find a file
Start typing the file name in the Search box.
Create a new folder to organize your files
Click New folder, and specify the folder name.
View files as large thumbnails or a list
Click the Card view button or the List view button in the upper-right corner of the project dashboard.
Sort files
Click the Sorting button , and click a command.
To share a file saved to the Cloud
Back to Top
1 Click File Open from Cloud to show the project dashboard.
2 Click the file.
A pane showing the file thumbnail is displayed to the right.
3 Click Share This File at the bottom of the file thumbnail.
4 In the Share File dialog box, do one of the following:
Click Copy to copy the link. From the Everybody with the link box, choose the access privileges of all people who will receive the link: Viewer, Reviewer, or Approver.
In the Private Sharing section, type the email addresses of the people you want to share the file with, and specify the access privileges for each person.
To sign out of Cloud
Back to Top
In CorelDRAW, click Help Sign out of Cloud.
