This Preferences page allows you to view and edit any of the keyboard shortcuts.
To set or change a shortcut
| 1. | Click in the Shortcut column next to the Action you want to edit. |
| 2. | Press the key or key combinations you want to assign to that action. |
| 3. | Click anywhere outside the row to apply your new keyboard shortcut. |
Note: Corel AfterShot Pro will warn you if you try to assign a shortcut that is currently being used by another Action. You may choose to Replace the shortcut, which will remove the shortcut from the previous action and will set the shortcut you've chosen, or you may cancel, keeping the previous settings.
© 2014 Corel Corporation. Note: The availability of features depends on the version of the software you have.
