This Preferences page allows you to view and edit Renaming Formats.
Renaming formats are a simple way to apply flexible renaming schemes. You can create new formats using any of the renaming formats that Corel AfterShot Pro supports. These renaming formats are used in the Export and Batch Export Settings dialog box and when renaming versions (Version > Rename Version).
| • | New format — opens a dialog where you can create new renaming formats. |
| • | Remove Current — removed the current, highlighted format from the list. |
To edit existing renaming formats
| • | Double-click the right column in the list and adjust the renaming format. |
© 2014 Corel Corporation. Note: The availability of features depends on the version of the software you have.
