CorelDRAW lets you add bookmarks and hyperlinks to your document. You can apply these to objects, including text objects, rollovers, and bitmaps. For information, see PDF hyperlinks, bookmarks, and thumbnails.
To create a link within a file, you can assign a bookmark to text or to an object. You can then assign a link to an object so that, when it’s clicked, it opens the bookmark.
You can also assign a hyperlink to an object. You can link to a web address, FTP server, email address, bookmark, or file. When the object is clicked, it opens to the assigned location in a appropriate application. After you create hyperlinks, you can display and verify them. You can also delete links and bookmarks. When working with text, you can assign a hyperlink to both artistic and paragraph text.
Type a web address, or URL, to the FTP server that opens when you click the link.
You can also assign a hyperlink from the Properties docker by clicking Window
Dockers
Properties to open the docker, and then clicking the Internet button.
