Embed graphics
You can embed a graphic object or bitmap in text. The graphic object or bitmap is treated as a text character. As a result, you can apply formatting options according to the type of text in which you embed the graphic object. You can also remove an embedded object from text, after which the object returns to its original state.
To embed a graphic object in text
Back to Top
1 Select a graphic object.
2 Click Edit, and click one of the following:
• Cut
• Copy
3 Using the Text tool , click where you want to embed the graphic object.
4 Click Edit Paste.
To remove an embedded object from text
Back to Top
1 Using the Text tool , select an embedded object.
2 Click Edit Cut.
3 Click the Pick tool , and click outside the text object.
4 Click Edit Paste.
