Fountain fills
A fountain fill is a smooth progression of two or more colors that adds depth to an object. Fountain fills are also known as gradient fills.
There are four types of fountain fills: linear, elliptical, conical, and rectangular. A linear fountain fill flows in a straight line across the object, a conical fountain fill creates the illusion of light hitting a cone, an elliptical fountain fill is dispersed in concentric ellipses from the center of the object, and a rectangular fountain fill is dispersed in concentric rectangles from the center of the object.
There are four types of fountain fills (left to right): linear, elliptical, conical, and rectangular.
The application provides a collection of fountain fills that you can access. You can browse the available fountain fills, search by keywords, mark fills as favorites, and sort fills. You can also download additional fill packs. For more information, see Find and view fills and transparencies.
Any fountain fill can be modified to suit your needs, and you can create your own fills from scratch. Fountain fills can contain two or more colors, which you can position anywhere in the fill’s progression. You can specify fill attributes such as the direction of a fill’s color blend, the fill’s angle, center point, and midpoint. You can also set the width and height of the fill as a percentage of the object’s width and height. Plus, you can smooth, skew, rotate, repeat, and mirror a fill.
You can edit fill properties from the Properties docker.
Left to right: An object with a linear fountain fill applied. Another color is added to the fill. The fill is resized to 50% of the object’s width and height, and then repeated and mirrored. Last, the fill is rotated 45 degrees.
After you create a fountain fill, you can save it for future use. For more information, see Save fills and transparencies.
You can adjust the print and display quality of the fountain fill by specifying the number of fountain steps. By default, the fountain steps setting is locked so that the print quality of the fountain fill is determined by the value specified in the print settings and the display quality is determined by the default value you set. However, you can unlock the fountain steps setting and specify a value that applies to both the print and view quality of the fill. For information about setting fountain fill steps for printing, see Fine-tune print jobs.
To apply a fountain fill
Back to Top
1 Select an object.
2 Click the Interactive fill tool in the toolbox, and then click the Fountain fill button on the property bar.
3 Open the Fill picker on the property bar, and double-click a fill thumbnail.
For information about how to find fills in the Fill picker, see To find, filter, and sort fills and transparencies.
You can also apply a fill by clicking a fill thumbnail in the Fill picker. This action applies the fill without closing the Fill picker.
You can add a color to a fountain fill by clicking the Interactive fill tool in the toolbox, clicking the Fountain fill button on the property bar, and dragging a color from the color palette to an object’s interactive vector handle.
To create a fountain fill
Back to Top
1 Select an object.
3 Click one of the following buttons to choose a fountain fill type:
• Linear fountain fill
• Elliptical fountain fill
• Conical fountain fill
• Rectangular fountain fill
4 Click the start node, open the Node color picker on the property bar, and choose a color.
5 Click the end node, open the Node color picker on the property bar, and choose a color.
6 Move the midpoint slider to set the midpoint between the two colors.
7 In the Properties docker, click the Save as new button to save the fill, or continue editing the fill by performing a task from the following table.
To
Do the following
Change the transparency of a color
Select the corresponding node, and type a value in the Node transparency box.
Add an intermediate color
Double-click the color band where you want to add a node. With the new node selected, open the Node color picker, and choose a color.
Change the position of an intermediate color
Drag the corresponding node to a new location above the color band, or type a value in the Node position box in the Properties docker.
Delete an intermediate color
Double-click the corresponding node.
Revert, mirror, repeat, or reverse the fill
Click the Arrangement button on the property bar, and click one of the following buttons:
• Default fountain fill
• Repeat and mirror
• Repeat
Click the Reverse fill button on the property bar.
The effect of repeating and mirroring can be seen only if the fill is smaller than the object. The following illustration shows a default fill (1), the same fill resized and then repeated and mirrored (2), the fill resized and repeated (3), and the fill reversed (4).
Specify how quickly the fountain fill blends from one color to another
Type a value in the Acceleration box on the property bar.
Create smoother color transitions between fountain fill nodes
Click the Smooth button .
Specify the way the colors blend between two nodes
Select either the two nodes or the midpoint between them, and in the Fill area of the Properties docker, and choose a blend direction option:
• Linear color blend — blends the colors along a straight line, beginning at the start color and continuing across the color wheel to the end color
• Clockwise color blend — blends the colors along a clockwise path around the color wheel
• Counterclockwise color blend — blends the colors along a counterclockwise path around the color wheel
The following color blend options are illustrated below from left to right: Linear color blend, Clockwise color blend, Counterclockwise color blend.
Set the width and height of the fill as a percentage of the object’s width and height
In the Properties docker, click the arrow button  at the bottom of the Fill section to display more fill options, and then type values in the W and H boxes.
Move the center of the fill up, down, left, or right
Type values in the X and Y boxes.
Slant the fill at a specified angle
Type a value in the Skew box.
In this example, the fill is skewed at 15 degrees.
Rotate the color progression clockwise or counterclockwise
Type a value in the Rotate box.
Allow the fill to be skewed or stretched disproportionately
Enable the Free scale and skew check box.
Apply the selected fill to the intersecting area of combined objects
Enable the Fill winding check box.
For more information, see Combine objects.
Let the fill print on top of the underlying colors.
Enable the Overprint fill check box.
You can also apply a custom fountain fill by clicking the Interactive fill tool  in the toolbox and dragging colors from the color palette in the document window onto the object’s interactive vector handles. You can mix colors by selecting one of the interactive vector handles, pressing Ctrl, and clicking a color on the color palette.
To change the fountain fill print and display quality
Back to Top
1 Select an object that has a fountain fill applied to it.
2 In the Properties docker, click the arrow button at the bottom of the Fill section to display more fill options.
3 Disable the Steps check box to unlock the fountain steps, and type a value in the Steps box.
Higher numbers create a smoother transition between colors.
When the Fountain steps box is locked, the number of steps in the printed fountain fill is determined by the value specified in the Print dialog box. For information about setting fountain fill steps for printing, see Fine-tune print jobs.
To set the display quality for fountain fills
Back to Top
1 Click Tools Options CorelDRAW.
2 In the left pane of the dialog box that appears, click Display.
3 Type a value in the Preview fountain steps box.
