PaintBrush (PCX)
The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file
Back to Top
1 Click File Import.
2 Locate the folder in which the file is stored.
3 Choose PCX - PaintBrush (*.pcx) from the list box next to the File name box.
4 Click the filename.
5 Click Import.
6 Click the drawing page.
To export a PaintBrush file
Back to Top
1 Click File Export.
2 Locate the folder in which you want to save the file.
3 Choose PCX - PaintBrush from the Save as type list box.
4 Type a filename in the File name list box.
5 Click Export.
6 In the Convert to bitmap dialog box, adjust the width, height, resolution, color mode, or any of the other settings.
7 In the Convert to paletted dialog box, adjust any of the settings.
PaintBrush (PCX) technical notes
Back to Top
Exporting a PCX file
• Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or RGB color (24-bit).
• Run-length encoding (RLE) compression is supported, and the maximum image size is 64,535 × 64,535 pixels.
• These files may contain one, two, or four color planes.
• This file format is supported in CorelDRAW and Corel PHOTO-PAINT.
Importing a PCX file
• PCX files can be imported if they conform to the following PCX specifications: 2.5, 2.8, and 3.0.
• RLE compression is supported and the maximum image size is 64,535 × 64,535 pixels.
• These files may contain one, two, or four color planes. Files containing three color planes or more than four color planes cannot be imported.
