You can customize color palettes.
Color palettes can be either docked or floating. Docking a color palette attaches it to the edge of the application window. Undocking a color palette pulls it away from the edge of the application window, so it floats and can be easily moved around.
With color swatches, you can set the right mouse button either to display a context menu or to set the outline color. You can also adjust the color swatch border and size, and you can hide or display the No color well.
You can also change the number of rows on a docked color palette by clicking Tools Options
Customization, clicking Color Palette in the left pane of the dialog box that appears, and typing a value in the Maximum palette rows when docked box. You can set a maximum of seven rows on a color palette.
If you enable the Set outline color option, you can still display the context menu by holding down the right mouse button for at least one second anywhere on the color palette.
You can also display color names in the color swatches by clicking the flyout button on a color palette and clicking Show color names.
