The symbols that you create in a drawing are saved with the CorelDRAW file. If you want to use the symbols in other drawings or share them with other users, you can save or export them to the Corel Symbol Library (CSL) format, creating a symbol library. When you save a drawing to the Corel Symbol Library (CSL) format, all symbol instances are saved with the document. When you export a library, only the symbols are saved with the document.
The Symbols docker displays the libraries that are in the local Symbols folder. The Symbols folder is the default location for custom symbol libraries that have been exported from CorelDRAW and imported libraries that are copied locally.
The symbols that are used within the document appear under the document filename in the Symbols docker.
You can add libraries and collections (groups of library files) to your drawing. You can also delete libraries and collections.
You can add symbols to an existing library.
You can also click the name of the active document in the Symbols docker, click the Options button and then click Export library. When you export a library, only the symbols are saved with the document.
By default, library files are referenced from their original location. If you want to copy a library to your Symbols folder, enable the Copy libraries locally check box.
If you are adding a collection, you can enable the Recursive check box to include subfolders.
The collection or library is removed from the folder tree in the Symbols docker, but files are not deleted.
