Find and replace colors
You can find a color in a drawing and replace it with another color. The color replacement can be applied to all outlines, uniform fills, fountain fills, 2-color fills, mesh fills, and monochrome bitmaps in the active document. Conversely, you can replace the color only in outlines or a specific type of fill. For example, you can replace the color only in uniform fills, and leave the color untouched in other fills and object outlines.
The selected green color used in outlines and two types of fills (a fountain fill and a mesh fill) is replaced with a purple color. Original artwork by Tricia Flohr.
You can also find and replace the color model or color palette of fills and outlines.
In addition, you can expand the search range to find and replace colors on multiple pages, or you can limit the search to only currently selected objects. For more information, see To set the search range.
To find and replace colors
Back to Top
1 Click Edit Find and Replace.
2 In the Find and Replace inspector, choose Replace Objects from the list box at the top of the inspector.
3 Enable the Color option.
4 In the Find area, click the Color picker, and choose a color. You can use the Color eyedropper tool to sample a color from the drawing or from an element that is outside the application window.
5 In the Replace area, click the Color picker, and choose a replacement color.
6 In the Apply to area, enable any of the following check boxes to specify where to apply the color replacement:
Outlines
Uniform fills
Fountain fills
2-color fills
Mesh fills
Monochrome bitmaps
7 Click any of the following buttons:
Find Next > or Find Previous < to scroll through objects that meet the search criteria.
Find All or Find All on Page to select all objects on the active page that meet the search criteria.
Replace to replace the color in the selected object.
Replace All to replace the color of all fills or outlines that meet the search criteria.
To find and replace the color model or color palette of fills and outlines
Back to Top
3 Enable the Color model or palette option.
4 Do one of the following:
Enable the Specific color model option in the Find area, and choose a color model from the list box. Choose a replacement color model from the Replace with list box.
Enable the Specific color palette option in the Find area, and choose a color palette from the list box. Choose a replacement color palette from the Replace with list box.
5 In the Apply to area, enable any of the check boxes to specify where to apply the color replacement.
6 Click the find or replace button you want.
