Find and view fills and transparencies
CorelDRAW lets you use, browse, and search vector patterns, bitmap patterns, and fountain fills that are available locally on your computer, on portable media devices, and in network folders. Any of these fills can also be used as transparency patterns.
To get you started, Corel provides local fills that are listed under All content in the Fill and Transparency pickers. These fills are stored in your Documents/Corel/Corel Content/Fills folder. If you are looking to expand your fill collection, you can download additional fill packs from within the Get More dialog box.
To access fills and patterns that are saved to local folders outside your Documents/Corel/Corel Content/Fills folder, you can create links to these folders in the Fill and Transparency pickers. Such links are known as aliases. In addition, aliases can be used to access fills saved to shared network locations as well as secondary storage devices such as USB flash drives, and portable hard drives.
You can also view the list of your favorite or most recently used fills and transparencies.
You can search and browse one pack, folder or list at a time. You can also browse and search your entire All content library by enabling the Browse recursively option.
When you copy a folder that contains many fills to your computer, it may take some time to index the folder. To view, browse, and search fills in such a folder right away, you may need to reindex the folder.
To find fills and transparencies more easily, you can filter them based on categories such Abstract, Animals, Floral, Nature, and more. You can also sort local fills and transparencies by name and the date they were created or modified.
The Fill picker lets you search, browse, and manage local and shared fills.
Fills and transparencies appear as thumbnail images. You can adjust the size of the thumbnails for easier and faster preview of fills and transparencies. In addition, you can resize the Fill picker or the Transparency picker to view more thumbnails at a glance.
To find, filter, and sort fills and transparencies
Back to Top
1 Select an object.
2 Click Object Properties.
3 In the Properties inspector, click one of the following buttons in the Fill or Transparency section:
Fountain fill or Fountain transparency
Vector pattern fill or Vector pattern transparency
Bitmap pattern fill or Bitmap pattern transparency
4 Open the Fill picker or the Transparency picker.
5 From the Choose content source list box, choose the local pack, folder, network location or list you want to search or browse. The items under All content show the fill packs provided by Corel and any fill packs and fills added by you.
To search, type a keyword in the Search box, and press Return.
You can also
Browse or search all items in your All content library
From the Choose content source list box, choose All content. Click the Options button , and click Browse recursively.
Reindex a folder
From the Choose content source list box, choose All content or an alias. Click the Options button , and click Reindex folder.
View the last 25 most recently used fills and patterns
From the Choose content source list box, choose Recent.
View your favorite fills and transparencies
From the Choose content source list box, choose Favorites. For information about how to mark a fill as favorite, see To manage fills and transparencies.
Filter fills and transparencies
From the Choose content source list box, choose a pack under All content or an alias. Choose a category from the Filter list box.
Sort fills and transparencies
From the Choose content source list box, choose a pack under All content or an alias. Click the Options button , and choose one of the following:
Sort by name sorts fills and transparencies by the fill name, in alphabetical order.
Sort by date created sorts fills and transparencies by the date they were created, starting with the last created fill.
Sort by last modified sorts fills and transparencies by the date they were modified, starting with the last modified fill.
Fills and transparencies in your Favorites list are automatically sorted by the date you marked them as favorites, starting with the last fill and transparency added to Favorites.
Fills and transparencies in your Recent list are automatically sorted by the date you used them, starting with the last used fill or transparency.
This procedure applies only to vector patterns, bitmap patterns, and fountain fills and transparencies.
To download and add a new fill and transparency pack
Back to Top
1 Open the Fill picker or the Transparency picker in the Fill or Transparency section of the Properties inspector.
2 Open the Choose content source list box, and click Add new.
3 Click Get More.
4 In the Get More dialog box, click the fill pack you want.
5 Do one of the following:
Click Buy, and follow the onscreen instructions to purchase the item.
Click Download if the item is included in your product or subscription.
To add an alias to a location that contains fills and transparencies
Back to Top
3 Click Create alias.
4 Browse to the folder or location you want.
5 Click Open.
To view the filename of a fill or transparency
Back to Top
In the Fill picker or the Transparency picker, Control-click a thumbnail, and click Properties.
To adjust the size of fill or transparency thumbnails
Back to Top
In the Fill picker or the Transparency picker, move the Thumbnail size slider.
To resize the Fill picker or the Transparency picker
Back to Top
Drag the lower-right corner of the Fill picker or the Transparency picker.
You can increase the width of the picker by dragging its right side, and you can increase the height of the picker by dragging its bottom side.
