Find, edit, and convert text
You can find text in a document and replace it automatically. You can also find and replace the properties of text objects. You can find special characters, such as an em dash or optional hyphen. You can edit text directly in the drawing window or in a dialog box.
Additional formatting options are available for paragraph text. To apply these formatting options to artistic text, you first need to convert the artistic text to paragraph text. Likewise, you can apply special effects to paragraph text by converting the text to artistic text. Converting text may result in the loss of any formatting.
You can also convert both paragraph and artistic text to curves. By transforming characters into lines or curve objects, you can add, delete, or move the nodes of individual characters to alter their shape. For more information, see Curve objects.
When you convert text to curves, the appearance of the text is preserved, including font, style, character position and rotation, spacing, and any other text settings and effects. Any linked text objects are also converted to curves. If you convert paragraph text in a fixed-sized text frame to curves, any text that overflows the text frame is deleted.
To find text
Click
Edit
Find and Replace.
In the
Find and Replace inspector, choose
Find and Replace Text from the list box at the top of the inspector.
Type the text that you want to find in the
Find box.
If you want to find the exact case of the text that you specified, enable the
Match case check box.
If you want to find whole words only, enable the
Find whole words only check box.
You can also find special characters by clicking the right arrowhead next to the Find box, choosing a special character, and clicking Find Next.
You can also expand the search range to find text on all document pages, a range of pages, or specific pages. Conversely, you can limit the search to only currently selected objects. For more information, see To set the search range.
To find and replace text
Click
Edit
Find and Replace.
In the
Enable the
Replace option.
4
Find box.
If you want to find only whole words, enable the
5
Type the replacement text in the
Replace box.
6
Click one of the following buttons:
Find Next > to scroll through occurrences of the text that is specified in the
Find box
Replace — replaces the selected occurrence of the text that is specified in the
Find box. If no occurrence is selected,
Replace finds the next occurrence.
7
Replace All — replaces every occurrence of the text that is specified in the
Find box
To find and replace text properties
Click
Edit
Find and Replace.
In the
Replace Objects from the list box at the top of the inspector.
Enable the
Text properties option.
4
In the
Find area, do any of following:
Enable the
Font check box and choose the font to find.
Enable the
Weight check box, and choose the text weight to find.
Enable the
Size check box, and choose the text size to find.
5
In the
Replace area, do any of following:
Enable the
Font check box and choose a replacement font.
Enable the
Weight check box, and choose a replacement text weight.
Enable the
Size check box, and choose a replacement text size.
6
Click
Find, and click any of the following:
Find Next > or
Find Previous < to scroll through text objects that meet the search criteria.
Find All to select all text objects that meet the search criteria.
Replace to replace the properties of the selected text object.
Replace All to replace the color of all text objects that meet the search criteria.
To edit text
Click the
Text tool
Perform a task from the following table.
Click in the artistic text.
Text that has been converted to curves cannot be edited.
To convert text
Convert paragraph text to artistic text
Using the Pick tool  , select the text, and click Text Convert to Artistic Text.
Convert artistic text to paragraph text
Using the Pick tool  , select the text, and click Text Convert to Paragraph Text.
Convert artistic or paragraph text to curves
Using the Pick tool  , select the text, and click Object Convert to Curves.
Paragraph text cannot be converted to artistic text when it’s in a linked frame, has text overflow, or has special effects applied to it.
You can also convert text to curves by clicking the Pick tool
, Control-clicking the text, and clicking Convert to Curves.
