Find templates
CorelDRAW provides an easy way of finding templates.
You can search by the file name, title, or keywords associated with a template. For example, if you type "certificate" in the text field, the application automatically filters out all files that do not match, and you see only the files that have the word "certificate" in the file name or keywords. You can cancel a search at any time.
You can narrow the search results by using the template source (for example, only templates created by you) and category (for example, Brochures, Flyers, or Letterheads & Letters). You can also view the list of your favorite or most recently used templates, and you can sort templates by the name and the date they were created or modified.
You can search and browse one pack, folder or list at a time. You can also browse and search your entire All templates library (the templates included with CorelDRAW and provided by third-party designers, as well as templates that you have created).
Add templates
To get you started, Corel provides local templates that are listed under All templates in the New from Template dialog box. These templates are stored in your Documents\Corel\Corel Content\Templates folder. If you are looking to expand your template collection, you can download additional template packs from within the Get More dialog box.
To access templates that are saved to local folders outside your Documents\Corel\Corel Content\Templates folder, you can create links to these folders. Such links are known as aliases. In addition, aliases can be used to access templates saved to shared network locations as well as secondary storage devices such as USB flash drives, and portable hard drives.
When you copy a folder that contains many templates to your computer, it may take some time for your operating system to index the folder. To view, browse, and search templates in such a folder right away, you may need to reindex the folder.
View template and template information
You can increase the size of thumbnails to recognize a particular template easier and faster, and you can decrease thumbnail size to view more search results at a glance.When you select a template in the viewing area, additional information is displayed about the template’s category, style, pagination, and fold options.
To find, filter, and sort templates
Back to Top
1 Click File New from Template.
2 From the Choose content source list box, choose All templates to search or browse the templates provided by Corel and any templates added by you.
3 Type a word in the Search box, and press Return.
Templates that match the search term appear in the left pane.
You can also
Filter templates
From the Choose content source list box, choose an item other than All templates. Choose a category from the Filter content list box.
View the most recently used templates
From the Choose content source list box, choose Recent.
View your favorite templates
From the Choose content source list box, choose Favorites. For information about how to mark a template as favorite, see To tag, rename, and delete templates.
Sort templates
Click the Options button , and choose one of the following:
• Sort by name sorts templates by template name, in alphabetical order.
• Sort by date created sorts templates by the date they were created, starting with the last created template.
• Sort by last modified sorts templates by the date they were modified, starting with the last modified template.
Templates in your Favorites list are automatically sorted by the date you marked them as favorites, starting with the last template added to Favorites.
Templates in your Recent list are automatically sorted by the date you used them, starting with the last used template.
Browse or search all items in your All templates library
From the Choose content source list box, choose All templates. Click the Options button , and click Browse recursively.
Reindex a folder
Click the Options button , and click Reindex folder.
When you choose My templates as the content source, you can browse all templates located in the root of your Documents\Corel\Corel Content\Templates folder.
To download and add a new template pack
Back to Top
2 Click the Get More button.
3 In the Get More dialog box, click the template pack you want.
4 Do one of the following:
• Click Buy Now, and follow the onscreen instructions to purchase the item.
• Click Download if the item is included in your product or subscription.
To add an alias to a location that contains templates
Back to Top
1 In the New from Template dialog box, open the Choose content source list box, and click Add new.
2 Click Create alias.
3 In the Locate template library dialog box, browse to the folder or location you want.
4 Click Select Folder.
To view templates and template information
Back to Top
1 In the New from Template dialog box, search for templates.
2 Perform one or more tasks from the following table.
To
Do the following
Increase or decrease the size of thumbnails
Move the Thumbnail size slider.
View template details
Click a thumbnail in the left pane. The template details are displayed in the right pane.
To hide the right pane where template details are displayed, disable the Show template details check box.
