You can draw a grid and set the number of rows and columns. A grid is a grouped set of rectangles that you can break apart.
You can change the default settings of the Graph Paper tool to specify the number of rows and columns for new grids.
If you want to draw the grid from its center point outward, hold down Shift as you drag; if you want to draw a grid with square cells, hold down Command as you drag.
You can also break apart a grid by clicking the Ungroup button on the property bar.
