Blend objects
CorelDRAW lets you create blends, such as straight-line blends, blends along a path, and compound blends. Blends are often used for creating realistic shadows and highlights in objects.
The highlights and shadows in the object on the right were created by using blends.
A straight-line blend shows a progression in shape and size from one object to another. The outline and fill colors of the intermediate objects progress along a straight-line path across the color spectrum. The outlines of intermediate objects show a gradual progression in thickness and shape.
After you create a blend, you can copy or clone its settings to other objects. When you copy a blend, the object takes on all the blend-related settings, except for the outline and fill attributes. When you clone a blend, changes you make to the original blend (also called the master) are applied to the clone.
Straight-line blends can be used to create graphics with a glass-like appearance. The rollover button (left) contains a blend of tightly overlapped blended objects.
You can fit objects along part or all of a path’s shape, and you can add one or more objects to a blend to create a compound blend.
The straight-line blend (top) is fitted to a curved path (bottom).
You can change the appearance of a blend by adjusting the number and spacing of its intermediate objects, the blend’s color progression, the nodes the blends map to, the blend’s path, and the start and end objects. You can fuse the components of a split or compound blend to create a single object.
This compound blend consists of three blends.
You can also split and remove a blend.
By mapping nodes, you can control the appearance of a blend. Two nodes on the polygon are mapped to two nodes of a star shape, showing a more gradual transition (bottom).
To blend objects
Back to Top
To
Do the following
Blend along a straight line
In the toolbox, click the Blend tool . Select the first object, and drag over the second object.
Blend an object along a freehand path
In the toolbox, click the Blend tool. Select the first object. Hold down Alt, and drag to draw a line to the second object.
Fit a blend to a path
In the toolbox, click the Blend tool . Click the Path properties button on the property bar. Click New path. Using the curved arrow, click the path to which you want to fit the blend.
Stretch the blend over an entire path
Select a blend that is already fitted on a path. Click the More blend options button on the property bar, and click Blend along full path.
Create a compound blend
Using the Blend tool, drag from an object to the start or end object of another blend.
You can also blend objects by using the Blend docker (Effects Blend).
To copy or clone a blend
Back to Top
1 Select the two objects that you want to blend.
2 Click Object, and click one of the following:
• Copy Effect Blend from
• Clone Effect Blend from
3 Select the blend whose attributes you want to copy or clone.
You can’t copy or clone a compound blend.
You can also use the Attributes eyedropper tool to copy a blend. For more information, see To copy effects from one object to another.
To set the number of intermediate objects in a blend
Back to Top
1 Select a blend.
2 Type a value in the Blend objects box on the property bar.
3 Press Enter.
You can set object and color acceleration rates by clicking the Object and color acceleration button on the property bar and moving the corresponding slider.
To set the distance between objects in a blend that is fit to a path
Back to Top
1 Select a blend that is fit to a path.
2 Click the Blend spacing button on the property bar.
3 Type a value in the Blend objects box on the property bar.
4 Press Enter.
If you have used the Blend along full path command, the Blend spacing button is unavailable.
To set the color progression in a blend
Back to Top
1 Select a blend.
2 On the property bar, click one of the following:
• Direct blend
• Clockwise blend
• Counterclockwise blend
You can’t create color progressions by using blended objects filled with bitmaps, texture, pattern, or PostScript fills.
You can set how fast the object’s colors transform from the first to the last object by clicking the Object and color acceleration button on the property bar and moving the corresponding sliders.
To map the nodes of a blend
Back to Top
1 Select a blend.
2 Click the More blend options button on the property bar, and click Map nodes.
3 Click a node on the start object and on the end object.
To work with the start or end objects in a blend
Back to Top
To
Do the following
Select the start or end object
Select a blend, click the Starting and ending objects button on the property bar, and click Show start or Show end.
Change the start or end object of a blend
Select a blend, click the Starting and ending objects button on the property bar, and click New start or New end. Click an object outside the blend that you want to use as the start or end of the blend.
Fuse the start or end object in a split or compound blend
Hold down Ctrl, click a middle object in a blend, and then click a start or end object. Click the More blend options button on the property bar. If you have selected the start object, click the Fuse start button . If you have selected the end object, click the Fuse end button .
You can reverse the direction of the blend by clicking Object Order Reverse order.
To change the blend path
Back to Top
1 Select a blend.
2 Click the Path properties button on the property bar, and click New path.
3 Click the path you want to use for the blend.
You can also
Detach a blend from a path
Click the Path properties button on the property bar, and click Detach from path.
Change the path of a selected freehand blend
Click the blend path with the Shape tool , and drag a path’s node.
To select the blend path, click the Path properties button , and click Show path.
To split a blend
Back to Top
1 Select a blend.
2 Click the More blend options button on the property bar.
3 Click the Split button .
4 Click the intermediate object at the point at where you want to split the blend.
You can’t split a blend at the intermediate object that is immediately adjacent to the start or end object.
To remove a blend
Back to Top
1 Select a blend.
2 Click Effects Clear blend.
You can also remove a selected blend by clicking Clear Blend on the property bar.
