Export objects and pages
CorelDRAW lets you manage and export assets using the Export docker. You can export one or more objects and pages, or a group of objects to the PDF, JPEG, PNG, SVG, EPS, TIFF, GIF, AI, DWG, and DXF formats.
To export an object, you must select it in the document and add it to the Export docker. To add the active page to the export list, you must deselect all objects on the page. You can also select multiple objects or pages and add them to the export list with a single click; each asset will appear as a separate entry in the list. For more information about selecting objects, see Select objects. For information on selecting pages, see Select and activate pages.
You can remove a selected item from the export list, and you can select all items in the list and remove them at once.
By default, when you add an asset for export, the filename that appears in the export list is the same as the name of the object in the Objects docker (Object Objects). To change the filename of an export item, you can rename it in the Export docker. You can also add a suffix to the filename to make it more meaningful and descriptive. For example, if you are exporting the same design asset to different sizes, you can add a suffix to indicate the size.
You can export an asset multiple times with different settings. For example, to quickly export a logo to the JPEG and PDF formats, add the logo once, duplicate it in the export list, and then adjust the options you want.
CorelDRAW also lets you reuse export settings. For example, to export several designs of a banner with the same settings, add the first design to the list and specify the export options. Next, select the other versions and add them to the export list with a single click by using the export settings of the first design. Export settings are object-specific; if you delete an object from a document, the object is automatically removed from the Export docker, and you can no longer use the settings associated with this item.
In the Export docker, pages are listed first and are arranged in the order in which they appear in the document regardless of the sequence in which you add them for export. All objects are listed next in the order in which they appear in the Objects docker. For example, in a multipage document, objects on page 1 will be listed before objects on page 5.
To manage export assets
Back to Top
• In the Export docker (File Export For Multiple Files), perform a task from the following table.
To
Do the following
Add an object to the export list
Select an object in the document window and click the Add new button .
Add the active page to the export list
Make sure all objects on the page are deselected and click the Add new button .
Add multiple assets to the export list
Select multiple assets in the document window, and click the Add new button .
Each asset is added as a separate item to the export list.
Remove an item from the export list
Click the Delete button beside the item you want to remove from the list.
Remove all items from the export list
Click the Select all button , and then click the Delete button at the bottom of the Export docker.
Duplicate an item in the export list
Click the Options button beside the item you want to duplicate, and click Duplicate.
Add an asset by reusing the settings of an item in the export list
In the document, select an asset. In the Export docker, click the Options button beside the entry whose settings you want to copy, and click Add Asset with These Settings.
Rename an asset
Click the name label, and enter a new name.
You can also open the Export docker by clicking Window Dockers Export.
To export an asset
Back to Top
1 Add an asset to the export list of the Export docker.
2 Choose a file format from the File format list box.
If you want to make the filename more descriptive and meaningful, enter a suffix.
3 Click the Destination folder button , and browse to the drive and folder where you want to save the file.
4 Click the Options button , and click Export Item.
You can also
Export multiple items
In the Export docker, enable the Select Item check boxes beside the items that you want to export. Click Export.
Tip: To export all items in the list, click the Select all button , and then click Export.
Modify export settings
In the Export docker, click the Settings button , and specify the options you want.
The Export button is grayed out when there are no items selected.
To export linked groups, such as contours, blends, extrusions, shadows, and objects created with the Artistic media tool , first group the objects in the linked group, and then add the group to the Export docker. For example, if you want to export an object with an inner shadow, create a group from the object and the shadow, and then add the group to the Export docker. For information about how to group objects, see To group objects.
To choose the default file format for new items
Back to Top
• From the Default file format list box at the bottom of the Export docker, choose a default file format.
