Fills
You can add colored, patterned, textured, and other fills to the inside of objects or other enclosed areas. You can customize a fill and set it as a default, so that each object you draw has the same fill.
Fill samples: Uniform, linear fountain, elliptical fountain, vector pattern, bitmap pattern, two-color, texture, and PostScript
This section contains the following topics:
Uniform fills
Fountain fills
Vector and bitmap pattern fills
Two-color pattern fills
Texture fills
PostScript fills
Mesh fills
Apply fills to areas
Work with fills
