Size and scale objects
CorelDRAW lets you size and scale objects. In both cases, you change the dimensions of an object proportionally by preserving its aspect ratio. You can change the dimensions of an object by specifying precise values or by changing the object interactively. When you scale an object, you change its dimensions by a specified percentage.
You can also scale an object by specifying the dimension for a portion of the object, and you can interactively set a portion dimension and origin point to scale an object.
To size an object
Drag any of the corner selection handles.
Type values in the Object size boxes on the property bar.
Size a selected object from its center
Hold down Shift, and drag one of the corner selection handles.
Size a selected object to a multiple of its original size
Hold down Ctrl, and drag one of the corner selection handles.
Stretch and size a selected object simultaneously
Hold down Alt, and drag one of the corner selection handles.
The anchor point of an object, also known as "object origin," remains stationary when you resize the object by typing values in the Object size boxes on the property bar. If you want to change the object origin, click a point on the Object Origin button
You can also size an object by clicking Window
Dockers
Transform, clicking the Size button
and then typing values in the Transform docker.
To scale an object
In the toolbox, click the
Free Transform tool
Click the
Free scale button
4
Type a percentage by which you want to scale the object in the
Scale factor boxes on the property bar.
Apply the scaling according to the object’s position rather than the x and y coordinates
Click the Relative to object button  on the property bar.
Scale an object using the Transform docker
Click Window Dockers Transform. Click the Scale and mirror button, type values in the X and Y boxes, and click Apply.
Leave the original object unchanged and apply the transformation to a copy
Click the Apply to duplicate button on the property bar, or type a number in the Copies box in the Transform docker.
The object origin, also known as "anchor point" or "reference point," can be the center of an object or any one of the object’s selection handles. The object origin remains stationary when an object is scaled by typing values in the Scale factor boxes on the property bar.
You can also scale an object by dragging a corner selection handle.
You can also scale an object by using the Transform toolbar. To open the toolbar, click Window
Toolbars
Transform.
To scale an object by portion
Click
Window
Dockers
Transform.
In the
Transform docker, click the
Size button
, and enable the
Scale portion option.
4
Type a value in the
Scale portion box, and then click
Apply.
5
Drag along the portion of the object that you want to scale.
Hold down
Shift to constrain to a straight line.
In the Transform docker, type a number in the Copies box.
To scale an object by portion interactively
Click
Window
Dockers
Transform.
In the
Size button
, enable the
Scale portion option, and then click the
Fit to Reference button
4
Drag to set the dimension and object origin, and then click
Apply.
The origin point is set with your first click.
5
Hold down
