Repairing the software lets you install (or reinstall) missing (or corrupted) components. You can repair a single installation of the software by using the Windows Control Panel on that workstation, or you can repair multiple workstation installations by using a command line.
Repairing a single installation
You can use the Windows Control Panel to repair a single installation.
Repairing multiple installations
You can use a command line to repair multiple installations at a time.
You cannot use the /f switch with public properties. For greater control over the repair process, use the REINSTALL and REINSTALLMODE properties instead of /f.
The /f switch has the following parameters.
The default parameters for /f are oums.
For greater control over how the software is repaired, use the REINSTALL and REINSTALLMODE public properties together.
Reinstalls all program features. If you prefer to reinstall only specific features (see Deploying a custom set of features for a list), use the following syntax:
REINSTALL=Feature |
