You can remove the software from your network. Uninstalling the software cleanly is crucial when the time comes to upgrade to a newer version.
You cannot automate the removal of a server image. Instead, you must manually delete the image from the server.
For best results with deleting an image, make sure that the programs to be removed — and their associated files — are not currently in use on the workstations.
The only way to recover a deleted server image is to re-create it by re-running the setup.
Don’t delete the server image if there are still workstations that use the image. Otherwise, users won’t be able to maintain and modify the installations.
Removing the software from a server
If Remote Desktop Services (formerly known as Windows Terminal Server) are used so that users can run the applications from a server, make sure that all users are logged off before you remove the software.
You can remove a single installation of the software by using the Windows Control Panel on that workstation, or you can remove multiple workstation installations by using a command line.
Removing a single installation
You can use the Windows Control Panel to remove a single installation.
Removing multiple installations
You can use a command line to remove multiple installations at a time.
If you want more control over the removal process, use the following public properties.
For example, if you want to uninstall both GPL Ghostscript and Windows Shell Extension, you can use the following command:
You can also use a msiexec command to uninstall both GPL Ghostscript and Windows Shell Extension.
