Deploying a custom set of features
When performing a basic or silent installation with the /q switch (see /q - Push the server image to the workstations), you may want to use the ADDLOCAL property together with the REMOVE property to specify a custom set of features to install. First, you use ADDLOCAL to include all features, and then you use REMOVE to specify which features you want to exclude.
ADDLOCAL=ALL REMOVE=Feature1,Feature2
For example, if you want to install all CorelDRAW Graphics Suite features except Corel PHOTO-PAINT and CAPTURE, use the following properties in the command line:
ADDLOCAL=ALL REMOVE=PP,Capture
You can specify a single feature, or a comma-separated list of components as shown in the following examples. However, we don’t recommend this method because it is tedious and error-prone; you may inadvertently exclude features that you want to install.
ADDLOCAL=Feature
ADDLOCAL=Feature1,Feature2
Feature names are case-sensitive.
