When performing a basic or silent installation with the /q switch (see /q - Push the server image to the workstations), you may want to use the ADDLOCAL property to specify which software languages to support. You can specify a single language:
Or you can specify a comma-separated list of languages:
Using language codes, you can specify language modules.
Some editions of the software do not include certain languages listed in this section.
If you use the ADDLOCAL property in your command line to specify only languages, you will exclude all other product features. Consider using the ADDLOCAL property together with REMOVE to install all features and exclude specific languages:
Language codes are case-sensitive.
Specifying UI modules by language code
A language module includes the software UI. By installing multiple language modules, you can enable dynamic language switching — the ability to change the language of the software UI.
The following table lists the available language modules for the software, along with their corresponding language codes.
By default, writing tools are automatically installed for all available languages.
