If your /a command line succeeds, the setup initializes in one of two ways:
You can no longer use the /q (n) switch for creating a server image with limited setup UI.
The Share feature usage feature on Windows is internet-based. When internet features are enabled, Corel tracks feature usage and uses this information to improve the applications.
The setup UI takes you step-by-step through the process of setting up the server image.
The Proof of Entitlement Certificate email contains the required serial number, which is assigned to the corel.com account used when creating the server image. For more information, see Before creating a server image.
To access your ProfileID, log in to your corel.com customer account. The ProfileID is displayed in the bottom-right corner.
This default deployment option is configured with internet features automatically enabled. Users at the workstations can access internet-based features such as QR codes, share feature usage (Windows only), and online Help.
To install with Internet features off, you need a special serial number. For more information, see Deployment with Internet features off.
Enable this check box to allow corporate users access to the Comments docker and Corel Cloud. For information about using a property to accomplish this task, see ALLOW_CORPORATECLOUDFEATURES.
When this check box is enabled, you can give users access to Corel Cloud, allowing them to sign in to the Comments docker with their own corporate accounts. For information about using a property to accomplish this task, see CDAENTERPRISEACCESS.
For more information about the available sign-in options, see Saving files in the Corel Cloud.
To create and deploy the server image, you must use a serial number that begins with either the prefix DR25C22 (for corporate licenses with maintenance) or DR25S22 (for volume subscriptions), and has 37 characters (including dashes). If your serial number has fewer characters, it is not a valid serial number for software deployment.
You must be online when creating the server image so that you can authenticate your profile. When you enter the email address and password associated with your Corel.com account when online, a ProfileID is generated that allows users to be signed in automatically.
To create a server image that allows the workstations to work in offline mode (with Internet features off), you must use a special serial number that begins with the prefix DR25CKV. Request this special serial number by sending an email to offlinedeploy@mysupport.corel.com. Make sure that the email includes the following information:
The full setup UI for creating a server image with Internet features off includes all components listed in Full setup UI, except for Deploy with internet features on. There is an additional UI component — Internet features. It is disabled by default, but you can enable it.
