Specifying the setup file
The most important item to specify in your command line is the executable file for the setup: the Setup.exe file on the server image you want to use:
\\server\path\x64\Setup.exe — to push the 64-bit version of the software to 64-bit operating systems
If your path contains spaces, you must place quotation marks around it:
"\\server\path containing spaces\Setup.exe"
