Add hotspots and alternate text to objects
You can also set a hotspot that follows the outline of the object, or fills the object’s bounding box. CorelDRAW applies a crosshatch pattern to an object containing a link. You can change the color of the crosshatch pattern as well as its background fill. In addition, you can add alternate text to objects for text-only browsers or screen readers.
To set a hotspot
Back to Top
1 Click Window Dockers Links and Rollovers.
2 In the workspace, click the object to which you want to add a hotspot.
3 In the Links and Rollovers docker, choose Link from the Behavior list box, and type a web address in the URL box.
4 In the Define hotspot using area, click one of the following buttons:
Shape — defines the hotspot using the object’s shape
Bounds — defines the hotspot using the object’s bounding box
5 Open the Background color picker , and click a color.
6 Open the Cross-hatch color picker , and click a color.
If you choose a hyperlinked object first and then change the crosshatch and background hotspot colors, the change applies to the selected object only.
To add alternate text to an object
Back to Top
2 In the workspace, click the linked object to which you want to add alternate text.
3 In the Links docker, type the alternate text in the Alt comments text box.
