Add tables
With CorelDRAW, you can add a table to a drawing to create a structured layout for text and images. You can draw a table, or you can create a table from existing text.
In this example, a table was used to organize the content.
To add a table to a drawing
Click the
Table tool
Type values in the
Rows and columns boxes on the property bar.
The value that you type in the top portion specifies the number of rows; the value that you type in the bottom portion specifies the number of columns.
Drag diagonally to draw the table.
You can also create a table by clicking Table
Create new table, and then typing values in the Number of rows, Number of columns, Height, and Width boxes.
To create a table from text
Click the
Pick tool
Select the text that you want to convert to a table.
Click
Table
Convert text to table.
4
In the
Create columns based on the following separator area, choose one of the following options:
Commas — creates a column where a comma appears and a row where a paragraph marker appears
Tabs — creates a column where a tab appears and a row where a paragraph marker appears
Paragraphs — creates a column where a paragraph marker appears
User defined — creates a column where a specified marker appears and a row where a paragraph marker appears
If you enable the
User defined option, you must type a character in the
User defined box.
If you do not type a character in the User defined box, only one column is created, and each paragraph of text creates a table row.
You can also convert a table to text. For more information, see To convert a table to text.
