Choose options
The following categories of options are available to help you match settings to your workflow.
Application Options (
Tools
Options
CorelDRAW) are specific to CorelDRAW. You can choose the application behavior on startup, customize display colors, and adjust auto-save and backup settings. Other application options apply to editing objects, text, your digital pen, snapping, PowerClip, PowerTRACE, warnings, and plug-ins.
Tool Options (
Tools
Options
Tools) let you set the default behavior of commonly used tools such as the
Pick,
Eraser,
Zoom,
Pan,
Rectangle,
Ellipse,
Connector,
Dimension, and
Mesh Fill tools.
Global Options (
Tools
Options
Global) affect the entire suite. You can choose the language of the user interface, adjust print settings, and change the location for saving content such as fills, fonts, and color palettes. You can also customize the list of the active file filters, and you can adjust privacy and personalization settings. For example, you can opt out of feature tracking, and you can update your profile to receive better recommendations for learning materials.
Document Options (
Layout
Document Options) apply to the active document. They include page size, page viewing mode, layout, grid, ruler, and guideline settings as well as duplicate offset. These options are available only when a document is open.
In addition, you can access color management options to manage document colors for display and printing. For more information, see Get started with color management.
Each category of options is accessible from a different menu command and brings up a specific page in the Options dialog box. If you cannot find the setting you need, you can switch to another category with a single click.
To switch to another category of options
Click one of the following buttons in the upper-right corner of the
Options dialog box:
Document
CorelDRAW
Customization
Tools
Global
Workspaces
Switch between categories by clicking the corresponding button in the Options dialog box.
