CorelDRAW and Cloud
You can save files created in CorelDRAW to the Cloud. A project dashboard helps you store, view, and organize files saved to the Cloud.
Important notes!
• The first time you access the Cloud from CorelDRAW, you will be prompted to sign in with the password associated with your Corel account. You need to sign in only once a year.
• An Internet connection is required to open files from and save files to the Cloud.
If you need to sign in with different credentials, you must first sign out of the Cloud (Help Sign out of Cloud).
To open a CorelDRAW (CDR) file saved to the Cloud
Back to Top
1 In CorelDRAW, click File Open from Cloud.
2 On the project dashboard, double-click the file you want to open.
You can also open a CDR file from the Cloud by clicking the Open from Cloud button on the standard toolbar.
To save a CorelDRAW (CDR) file to the Cloud
Back to Top
1 In CorelDRAW, click File Save to Cloud.
2 On the project dashboard, choose the folder where you want to save the file, and type a file name.
3 Click Save to save the file and upload it to the Cloud.
You can also
Save the file to the CorelDRAW (CDR) file format, or to an earlier version of CorelDRAW
Choose the file format and version from the File format and version box.
Break the link between a file saved to the Cloud and its locally saved version
In CorelDRAW, click File Save As, and save the file to the local folder you want.
A file saved to the Cloud can be identified by the cloud icon beside its name .
You can also save a CorelDRAW file to the Cloud by clicking the Save to Cloud button on the standard toolbar.
To find, organize, and view files saved to the Cloud
Back to Top
1 Click File Save to Cloud or File Open from Cloud to show the project dashboard.
2 Perform a task from the following table.
To
Do the following
Find a file
Start typing the file name in the Search box.
Create a new folder to organize your files
Click New folder, and specify the folder name.
View files as large thumbnails or a list
Click the Card view button or the List view button in the upper-right corner of the project dashboard.
Sort files
Click the Sorting button , and click a command.
To sign out of Cloud
Back to Top
• In CorelDRAW, click Help Sign out of Cloud.
