Get started with Microsoft SharePoint
CorelDRAW gives you direct access to your organization’s Microsoft SharePoint document management system (DMS).
The Document Management feature is available only if your organization has licensed CorelSure Maintenance.
To use your organization’s DMS with CorelDRAW, you must log in to SharePoint by using your SharePoint credentials, not your Corel.com account credentials.
Saving documents to a document library
You can share CorelDRAW (CDR) documents with others by saving them to your organization’s document library. After you save a document to the document library, others can view the document, or check it out, provided they have the permission to do so.
Using the working folder
By default, CorelDRAW places a folder called "Working Files" in My Documents, so the location of the default working folder is as follows:
Users\<Your name>\Documents\Working Files
The file you check out is copied to the working folder, and you can modify the file in CorelDRAW from that location. When you are ready to check in the changes, the file is copied from the working folder back into the SharePoint document library. For information about checking out files, see Check documents in and out of a document library.
You can change the working folder, although you should never need to do so.
You must check in all checked-out files before changing the working folder. If you change the working folder while files are checked out; you will not be able check them in from within CorelDRAW.
To save a document to a document library for the first time
Back to Top
1 Click File Document Management Save.
2 In the Save dialog box, type the document library URL in the Look in text box, and then press Enter. The URL must have the proper format: http://[ServerName]/[Site]/[Name].
The document library page appears.
3 Browse to the location where you want to save the file.
4 Type a name for the document in the File name box.
5 Click Save.
You can save only CorelDRAW (CDR) documents.
To save the document to a local folder, click File Save As.
To change the working folder
Back to Top
1 Check in all checked-out files.
2 Click Tools Options Global.
3 In the Options dialog box, click File Locations.
4 Click Documents, and click the Browse button , located to the right of the file path.
5 In the Browse for Folder dialog box, navigate to the folder you want.
If you want to move the documents saved to the old location to the new folder, click Yes in the Move Content dialog box.
You can also
Reset the location of the working folder
Click Documents, and click Reset.
To display the Document Management toolbar
Back to Top
Click View Toolbars Document Management.
