Manage fills and transparencies
The Fill and Transparency pickers let you manage the list of your local packs and aliases (links to local folders, network locations, and secondary storage devices). For example, you can rename the local packs or aliases, and you can remove aliases from the list. If an alias no longer works because the fill folder has been moved, you can browse to the new location to restore the link.
To find the fills and transparencies you like with ease, you can mark them as favorites. In addition, you can view and change the properties of a fill or transparency. For example, you can change its name and language; and you can add new tags and delete existing tags. When you no longer need a fill or transparency, you can delete it.
To update the list of fill packs in the Fill and Transparency pickers
Open the
Fill picker or the
Transparency picker from the property bar or the
Fill or
Transparency section of the
Properties docker.
Choose a fill pack from the
Choose content source list box under
All content.
Click the
Options button
, and perform a task from the following table.
Click Rename, and in the Rename dialog box, type a name in the Name box.
Open the fill pack in Windows Explorer
Click Open folder location.
Click Open folder location. Select the folder that contains the pack in Windows Explorer, right-click it, and click Delete.
This action deletes the fill pack and removes it from the list in the Fill and Transparency pickers.
To update the list of aliases in the Fill and Transparency pickers
Open the
Fill picker or the
Fill or
Properties docker.
Choose an alias from
Choose content source list box.
Click the
Options button
Browse to a folder that has been moved or renamed
Click Browse, and navigate to the folder that contains the fills.
Remove the alias from the list
Open the folder in Windows Explorer
To manage fills and transparencies
Click
Object
Properties.
In the
Properties docker, click one of the following buttons in the
Fill or
Transparency section:
Fountain fill
or
Fountain transparency
Vector pattern fill
or
Vector pattern transparency
Bitmap pattern fill
or
Bitmap pattern transparency
4
Open the
Fill picker or the
Transparency picker.
5
Perform an action from the following table.
Mark a fill or pattern as a favorite
Right-click a thumbnail, and click Favorite.
Change the name of a fill or pattern in your local library, or the tags associated with it
Right-click a thumbnail, and click Properties. In the Properties dialog box, do any of the following:
• Choose a language from the Language list box.
• Type a new name in the Title box.
• Choose a category from the Category list box to categorize the fill or pattern.
• Add to or delete tags from the Tags box.
Delete a fill or pattern from your local library
Right-click a thumbnail, and click Delete.
This procedure applies only to vector patterns, bitmap patterns, and fountain fills and transparencies.
