Manage templates
You can manage the list of your local template packs and aliases (links to local folders, network locations, and secondary storage devices). For example, you can rename the local packs or aliases, and you can remove aliases from the list. If an alias no longer works because the template folder has been moved, you can browse to the new location to restore the link.
To find the templates you like, you can mark them as favorites. In addition, you can view and change the properties of a template. For example, you can change its title and language, add new tags, and delete existing tags. You can change the template category, or you can assign a custom category to a template. When you no longer need a template, you can delete it.
To update the list of template packs and aliases
Click
File
New from Template.
Click the
Options button
Choose content source, and choose a template pack or an alias.
Click the
Options button
, and perform a task from the following table.
Rename a template pack or alias
Click Rename, and in the Rename dialog box, type a name in the Name box.
Browse to a folder that has been moved or renamed
Click Browse, and navigate to the folder that contains the templates.
Remove the alias from the list
Open the template pack or alias in Windows Explorer
Click Open folder location.
To tag, rename, and delete templates
Click
File
New from Template.
Perform an action from the following table.
Tag a template as favorite
Right-click a thumbnail, and click Favorite.
Change the name of a template in your local library, or the tags associated with it
Right-click a thumbnail, and click Properties. In the Properties dialog box, do any of the following:
• Choose a language from the Language list box.
• Type a new name in the Title box.
• Add or delete tags in the Tags box.
• Choose a category from the Category list box to categorize the template.
• To assign a custom category, choose New category from the Category list box, and type the category name in the box.
Delete a template from your local library
Right-click a thumbnail, and click Delete.
