Manage warning messages
You may encounter warning messages while working in the application. Warning messages explain the consequences of an action you are about to perform, and inform you of permanent changes that might result from that action. Although the warnings are helpful, you can disable them so you don’t have to view them after you become familiar with the software. Avoid disabling warning messages until you are comfortable with the application and familiar with the results of the commands you use. If needed, you can enable the warnings at any time.
To manage warning messages
Back to Top
1 Click Tools Options CorelDRAW.
2 Click Warnings.
3 Disable or enable one or more of the check boxes.
