Modify guidelines
After you add a guideline, you can select it, move it, rotate it, or lock it in place. You can also change the line style and color of guidelines.
To select a guideline
Select a single guideline
Click the guideline with the Pick tool  .
Select all guidelines on a page
Click Edit Select all Guidelines. The local guidelines and master guidelines are selected.
To move or rotate a guideline
Click
Window
Dockers
Guidelines.
Perform any of the following tasks.
Specify the new location of the guideline in the x and y boxes, and click Modify.
You can also drag a guideline to a new position in the drawing window.
Choose Angled from the Guideline type list box, type a value in the Angle of rotation box, and click Modify.
You can also use the Pick tool  to click the guideline twice and then rotate the guideline when skewing handles appear.
To lock or unlock a guideline
Right-click the guideline, and click
Lock or
Unlock.
You can also click Window
Dockers
Guidelines and click the Lock guideline button
To set the line style and color of a guideline
Click
Window
Dockers
Guidelines.
Open the
Guideline color picker, and choose a guideline color.
Open the
Guideline style picker, and choose a line style.
