Preview RAW camera files and obtain image information
By previewing RAW camera files in various ways, you can evaluate the color and tone adjustments you make. For example, you can rotate images, pan to a new area, zoom in or out, and choose how to display the processed image in the preview window.
You can obtain information about the color mode, size, and resolution of a RAW camera file. In addition, you can obtain information about the camera and camera settings used when the photo was taken.
To preview a RAW camera file
Click
File
Import.
Select the RAW camera file or files that you want to import, and click
Import.
In the
Camera RAW Lab, perform a task from the following table.
Pan to another area of an image
Using the Pan tool  , drag the image until the area that you want to see is visible.
Using the Zoom in tool  or Zoom out tool  , click in the preview window.
You can also zoom in and out by dragging the Zoom slider.
Fit an image in the preview window
Click the Zoom to fit  button.
Display an image at its actual size
Click the 100%  button.
View the corrected image in a single preview window
Click the Full preview button  .
View the corrected image in one window and the original image in another window
Click the Before and after full preview button  .
View the image in one window with a divider between the original and corrected versions
Click the Before and after split preview button  . Move your pointer over the dashed divider line, and drag to move the divider to another area of the image.
To obtain information about a RAW camera file
In the
Camera RAW Lab, click the
Properties tab, and view any of the properties that are available for the selected RAW camera file, such as color space, camera manufacturer and model, focal length, exposure time, and ISO speed ratings.
