Rollovers
Rollovers are interactive objects that change in appearance when you click or point to them. You can create rollovers using objects.
To create a rollover, you add the following rollover states:
Normal — the default state of a button when no mouse activity is associated with the button
Over — the state of a button when the pointer passes over it
Down — the state of a clicked button
You can apply different object properties to each of the rollover states. You can also preview the rollover states.
Rollovers showing Normal (left), Over (center), and Down (right) states
To create a rollover object
Click
Object
Rollover
Create Rollover.
To modify an object’s rollover state
Click the rollover object to select it.
Click
Window
Dockers
Links and
Rollovers.
In the
Links and Rollovers docker, click the
Edit rollover button
, and choose a state from the
Active rollover state list box:
4
Modify the object properties, such as the color.
5
Repeat steps 4 and 5 to modify the other states if needed.
6
Click the
Finish editing rollover button
On the Internet toolbar, click the Delete rollover state button  .
Duplicate a rollover state
On the Internet toolbar, click the Duplicate rollover state button  .
On the Internet toolbar, click the Extract rollover objects button  .
Specify what frame appears when the rollover is clicked
On the Internet toolbar, chose a target frame from the Target list box.
You cannot close a drawing in which you are editing a rollover. You must finish editing first.
Rollover objects in edit mode cannot be brought into Focus mode, but rollover objects not already in edit mode can be brought into focus. Entire rollover objects can be brought into focus, but not individual rollover state objects. For more information about Focus mode, see Edit objects in Focus mode.
To preview a rollover
Click
Object
Rollover
Rollover Live Preview.
In the drawing window, point to the rollover to view the
Over state, and click the rollover to view the
Down state.
To view rollover properties
Click
Window
Dockers
Objects.
In the
Objects docker, click the page and layer where the
rollover resides.
Click the rollover name, and expand the
Normal,
Over, and
Down states.
You can preview a rollover object’s states in the drawing page by clicking Object
Rollover
