Spell Check and Grammatik
By using the spelling checker and Grammatik, you can check the spelling and grammar in an entire drawing, part of a drawing, or only selected text. You can also check the spelling or grammar of dates, time, currency symbols, text or look up a word in a different language.
You can manually edit text and then resume checking the drawing.
The spelling checker and Grammatik replace words or phrases in two ways: you can choose a word, or define an automatic replacement for a word. Defining automatic replacement words is useful for words that are regularly misspelled. Automatic replacement words are stored in a user word-list file. For more information about user word-list files, see Word lists.
You can skip a writing error once but flag subsequent occurrences of the problem, or you can skip the error throughout the entire proofreading session.
To check the spelling or grammar in an entire drawing
Click
Text
Writing tools, and click one of the following:
Choose
Document from the
Check list box.
To check the spelling or grammar in a different language, click
Options
Language, and select a language.
By default, the
Auto start command is enabled for the spelling checker and Grammatik. If you disable the
Auto start command (
Options
Auto start), you must click the
Start button in the
Writing tools dialog box to check a drawing.
To check the spelling or grammar in part of a drawing
Click the
Text tool
and click in a text frame.
Click
Text
From the
Check list box, choose one of the following:
Options
By default, the
Options
Start button in the
The options available in the Check list box vary according to the type of drawing that you are checking.
To check the spelling or grammar of selected text
Select the text you want to check.
Click
Text
Options
By default, the
Options
Start button in the
To edit text manually
Click
Text
When the spelling or grammar checker stops on a word or phrase, click in the
Replace with box, and edit the text.
To replace a word or phrase
Click
Text
When the spelling or grammar checker stops, choose a word or phrase from the
Replacements list.
If the spelling checker does not offer replacement words, you can edit text manually in the Replace with box.
To define automatic text replacements
Click
Text
When the spelling or grammar checker stops on a word, click
Auto replace.
To skip a spelling or grammar error
Click
Text
When the spelling or grammar checker stops, click one of the following:
Skip once — to skip an error once
Skip all — to skip all occurrences of an error
You can also skip all occurrences of a word for all proofreading sessions by adding it to a user word list. For more information about user word-list files, see Word lists.
