Standard toolbar
The standard toolbar, which appears by default, contains buttons and controls that are shortcuts to many of the menu commands. For information about customizing the contents and appearance of the toolbar, see Customize toolbars and other command bars.
Choose and open a document from the Cloud.
Save and upload a document to the Cloud.
Cut selected objects to the Clipboard
Copy selected objects to the Clipboard
Paste the Clipboard contents into a drawing
Restore an action that was undone
Display Full-screen preview
Disable all snapping. Click again to restore the selected snapping options.
Enable or disable automatic alignment for the pixels, document grid, baseline grid, guidelines, objects, and page
Open the CorelDRAW Options dialog box
Start Corel applications and plug-ins, or access the Get More dialog box to download other creative tools
More about toolbars
In addition to the standard toolbar, CorelDRAW has toolbars for specific tasks. For example, the Text toolbar contains commands relevant to using the Text tool. If you use a toolbar frequently, you can display it in the workspace at all times.
For information about customizing the position, contents, and appearance of toolbars, see Customize toolbars and other command bars.
The following table describes toolbars other than the standard toolbar.
Contains commands for zooming in and out of a drawing page by specifying percentage of original view, clicking the Zoom tool, and selecting a page view
Contains commands for formatting and aligning text
Contains commands for converting objects to PowerClip frames and text frames, displaying alignment guides as well as setting columns and margins
Contains commands for skewing, rotating, and mirroring objects
Contains commands for editing, testing, and running macros
Contains commands for web-related tools for creating rollovers and publishing to the Internet
Contains controls that let you track the time spent on project tasks
To toggle between displaying and hiding a toolbar, click Window
Toolbars, and click the command with the toolbar name.
To lock all toolbars so that you don’t inadvertently change their position, click Window
Toolbars
Lock toolbars.
