Work with bitmaps
You can convert a vector graphic to a bitmap. You can also import and crop bitmaps.
You can add perspective, shape bitmaps with envelopes, apply color masks, watermarks, and special effects, and change the color and tone of the images. For information about applying perspective to bitmaps, see Apply perspective. For information about shaping bitmaps with envelopes, see Shape objects by using envelopes. For information about applying effects to bitmaps, see Bitmap effects.
This section contains the following topics:
• Convert vector graphics to bitmaps
• Crop bitmaps
• Bitmap dimensions and resolution
• Straighten bitmaps
• Correct perspective distortions
• Remove artifacts and noise from JPEG images
• Remove dust and scratch marks from bitmaps
• Sharpen images
• Change and mask colors in bitmaps
• Image Adjustment Lab
• Adjust color and tone
• Tone Curve filter
• Transform color and tone
• Edit bitmaps with Corel PHOTO-PAINT
