Zoom, pan, and scroll
You can change the view of a drawing by zooming in to get a closer look or by zooming out to see more of the drawing. You can experiment with a variety of zoom options to determine the amount of detail you want.
You can also zoom in and out in preset increments by using common keyboard shortcuts, supported by web browsers and other applications.
Panning and scrolling are two additional ways to view specific areas of a drawing. When you work at high magnification levels or with large drawings, you may not be able to see the whole drawing. Panning and scrolling let you move the page around in the drawing window to view previously hidden areas.
You can use the Pan tool to pan around a large image and view particular areas.
You can also use the Quick Pan mode to switch from any active tool to the Pan tool. This feature lets you pan without having to change tools.
You can zoom in and out while you are panning, and you can pan while you are zooming. In this way, you can avoid having to alternate between the two tools. You can also specify default zooming and panning settings.
If you use a mouse wheel, the wheel zooms in and zooms out by default. You can set custom zoom increments for zooming with the mouse wheel. You can also use the mouse wheel to scroll.
By default, when zooming with a mouse and panning with the Pan tool, you are viewing the document at high resolution. However, you can show a low-resolution document preview for any device or method you are using to zoom and pan. You can also hide the low-resolution document preview for any device and method.
You can scroll a drawing by using the scroll bars that border the drawing window. You can show or hide the scroll bars.
To zoom
In the toolbox, click the
Zoom tool
On the property bar, click one of the following:
Zoom in
— lets you increase the magnification level
Zoom out
— lets you decrease the magnification level
Zoom to selected
— adjusts the magnification level to fit the selected objects on the active page or the selected pages in multipage view
Zoom to all objects
— adjusts the magnification level to fit all objects on the active page
Zoom to all pages
— adjusts the magnification level to fit all pages in multipage view
Zoom to page
— adjusts the magnification level to fit the active page
Zoom to page width
— adjusts the magnification level to fit the width of the active page
Zoom to page height
— adjusts the magnification level to fit the height of the active page
The Zoom to all pages button
is available only in multipage view. For more information about multipage view, see Page views.
The Zoom to selected button
is available only if objects or pages are selected before you click the Zoom tool.
You can also zoom in, zoom out, and zoom to all objects by using the Zoom In, Zoom Out, and Zoom to Fit commands in the View menu.
When you are not editing text, you can also access the Zoom tool by pressing Z.
Using the Zoom tool, you can also zoom in by clicking anywhere in the drawing window or dragging to select a specific area to magnify. To zoom out, right-click in the drawing window, or drag with the right mouse button to select a specific area.
You can also zoom in by using the Pan tool
and double-clicking in the drawing window. To zoom out, right-click in the drawing window.
To zoom using keyboard shortcuts
Do one of the following:
To zoom in, press
Ctrl+(+).
To zoom out, press
Ctrl+(-).
To zoom to all objects, press
F4.
To zoom to selected object, press
Shift+F2.
To zoom to page, press
Shift+F4.
You can use these keyboard shortcuts to adjust the zoom level in the document window as well as in dialog boxes and labs that feature preview windows such as the Print Preview dialog box, PowerTRACE, Image Adjustment Lab, and more.
To pan in the drawing window
Pan tool
When you are not editing text, you can also access the Pan tool by pressing the H key.
To pan in the drawing window while zoomed in on the drawing, click the Navigator button
in the lower-right corner of the drawing window. To access the Navigator button, the scroll bars must be displayed. For more information, see To hide or display the scroll bars.
Using the Navigator, you can display any part of a drawing without having to zoom out.
You can quickly center the page in the drawing window by double-clicking the Pan tool in the toolbox.
To switch to the Quick Pan mode
Click any selection, drawing, or shaping tool, and start using it.
Hold down the middle mouse button or wheel, and drag in the drawing window.
To specify default zoom settings
Click
Tools
Options
Tools.
In the left pane of the dialog box that appears, click
Zoom/Pan.
To specify the action of the
Zoom or
Pan tool when you right-click in the drawing window, enable one of the following options:
Zoom out — zooms out by a factor of 2
Context menu — displays a menu of commands that let you zoom to a specific level
4
To specify how the page appears when the zoom is set to 100%, enable or disable the
Zoom relative to 1:1 check box.
When the option is enabled, a 100% zoom displays real-world dimensions.
When the option is disabled, a 100% zoom displays the full page, regardless of real-world dimensions.
5
To specify how the page appears when you zoom in and out using the mouse wheel, enable or disable the
Center mouse when zooming with the mouse wheel check box.
When the option is enabled, the area where the mouse pointer is located moves to the center of the screen as you zoom in and out using the mouse wheel.
When the option is disabled, the area where the mouse pointer is located stays in the same position as you zoom in and out using the mouse wheel.
To choose default settings for the mouse wheel
Click
Tools
Options
CorelDRAW.
Display.
To specify the default action of the mouse wheel, choose
Zoom or
Scroll from the
Default action for mouse wheel list box.
Set the increments for zooming with the mouse wheel
Move the Zoom rate slider.
Set the increments for zooming with the mouse wheel while holding down Ctrl + Shift (Alternate Zoom)
Move the Alternate Zoom (Ctrl + Shift) rate slider.
By default, Alternate Zoom is faster than regular zooming, but you can customize it to be at a slower speed.
Restore the default increments for zooming with the mouse wheel
Click the Reset button next to the Zoom rate and Alternate Zoom (Ctrl + Shift) rate sliders .
4
Options dialog box, click
Display.
To hide or display a low-resolution preview while zooming and panning
Click
Tools
Options
CorelDRAW.
Display.
In the
Navigation area, choose one of the following from the
Low-resolution preview for responsive zooming and panning box:
Hide for mouse — shows the document at high resolution when you zoom with a mouse and pan with the
Pan tool, but enables a low-resolution preview for other methods such as touch
Always show — shows a low-resolution preview of the document for all methods and devices used to zoom and pan
Never show — always hides the low-resolution preview and shows the document at high resolution
To scroll by using a mouse wheel
To scroll vertically, move the wheel.
To scroll horizontally, press
Shift while you move the wheel.
The mouse wheel can be used for scrolling when the Scroll option for the mouse is enabled. For more information, see To choose default settings for the mouse wheel.
If the Zoom option for the mouse is enabled, you can scroll vertically by holding down Alt while you move the mouse wheel.
Click
View
Scroll Bars.
A check mark beside the
Scroll Bars command indicates that the scroll bars are displayed.
