Format Asian text
Asian character input is supported in CorelDRAW only when using an appropriate operating system or when language support is installed on a non-Asian operating system. You can choose a default font and text orientation (either horizontal or vertical) when typing text. When you type artistic or paragraph text, the program uses a default artistic or paragraph text style.
When you insert Asian or Middle Eastern text in existing Latin text, the application automatically matches the font of the Latin text if the font is available in the corresponding language. However, you can disable the font matching option so that the inserted text has the default font specified for Asian or Middle Eastern languages. For more information, see To disable font matching in multilingual text.
To choose a default font for Asian text
Back to Top
1 Click the Text tool .
2 Press Esc to ensure that no objects are selected.
3 Choose an input method from the Input menu on the menu bar.
4 Choose a font from the Font list box on the property bar.
5 Choose a font style from the Font style list box.
To choose a text orientation for Asian text
Back to Top
1 Using the Pick tool , select the frame that contains the text whose orientation you want to change.
2 Click Window Inspectors Properties.
3 In the Properties inspector, click the Frame button to display the frame-related controls.
4 Choose one of the following orientation options from the Text orientation list box:
Horizontal
Vertical
The default orientation for Asian text is horizontal.
When you change the text orientation from horizontal to vertical, underlines become left lines and overlines become right lines.
The text orientation setting applies to the entire text object. You cannot have text with different orientations in one text object.
If you have Asian text support installed with your operating system, you can also change text orientation by clicking the Vertical text orientation or Horizontal text orientation buttons on the property bar when the Text tool is active.
