Help and tooltips
The Help provides comprehensive information about product features from within the application.
An active Internet connection is required to access the help. The Help is also available online as a user guide in a print-friendly PDF format. If you often work offline, you can download the CorelDRAW User Guide.
You can browse through the entire list of topics or search for specific words. You can also access the Corel Knowledge Base on the Corel website and other online resources, such as videos, from the Help window.
Tooltips provide helpful information about application controls when you position the pointer over icons, buttons, and other user interface elements. You can hide all tooltips, and you can display them again when you need them.
To use the Help
Back to Top
1 Click Help CorelDRAW Help.
2 Perform a task from the following table.
To
Do the following
Browse through topics in the Help
Click a topic heading in the left pane.
Search the full text of the Help for a particular word or phrase
Type a word or phrase in the search box.
For example, if you are looking for information about the RGB color mode, you can type RGB to display a list of relevant topics.
Choose a topic from the list that appears.
Tip: If your search results do not include any relevant topics, check whether you spelled the search word or phrase correctly. Note that the English Help uses American spelling (for example, "color," "favorite," "center," and "rasterize"), so searching for British spellings ("colour," "favourite," "centre," and "rasterise") produces no results.
You can also access the Help by pressing Shift + Command + Question mark (?).
View context-sensitive Help from within a dialog box by clicking the Help button in the dialog box.
To access the CorelDRAW User Guide
Back to Top
• Click Help User Guide.
An active Internet connection is required to access the User Guide. If you often work offline, download the User Guide from product.corel.com.
To hide and show tooltips
Back to Top
1 Click CorelDRAW menu Preferences CorelDRAW.
2 Click Display.
3 In the Other controls area, disable or enable the Show tooltips check box.
