Add hotspots and alternate text to objects
You can also set a hotspot that follows the outline of the object, or fills the object’s bounding box. CorelDRAW applies a crosshatch pattern to an object containing a link. You can change the color of the crosshatch pattern as well as its background fill. In addition, you can add alternate text to objects for text-only browsers or screen readers.
To set a hotspot
Click
Window
Dockers
Links and Rollovers.
In the workspace, click the
object to which you want to add a hotspot.
In the
Links and Rollovers docker, choose
Link from the
Behavior list box, and type a web address in the
URL box.
4
In the
Define hotspot using area, click one of the following buttons:
Shape — defines the hotspot using the object’s shape
Bounds — defines the hotspot using the object’s bounding box
5
Open the
Background color picker
, and click a color.
6
Open the
Cross-hatch color picker
If you choose a hyperlinked object first and then change the crosshatch and background hotspot colors, the change applies to the selected object only.
To add alternate text to an object
Click
Window
Dockers
In the workspace, click the linked
object to which you want to add alternate text.
In the
Links docker, type the alternate text in the
Alt comments text box.
